How much is too much?
Weight that is.
Got 280lbs., riding on the tractor ( my body weight ) 52lbs. On the wheels, 46lbs., on a rear gizmo attached to the rear hitch. That's 378 total weight on a hydrostatic trans., & that's a lot. Great traction but isn't that toooooooo much pressure/wear for the gears in the rear or trans? Do others have more? Is there an suggested weight ratio for the limit? NIK,
It dont cut grass, but its yellow. |
my 215lb butt
95lb in each wheel = 405 lbs the 882 has filled tires with 75lb in the wheel + the 215lb
Doug Original / IH 70 / IH 149 / IH 1650 / IH 582 / CCC 1772 West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
I have 550 extra lbs on my 1200 when i sit on it tires are loaded and 2 sets of weights so 150 a side and my 250. So far so good.ha
Original,100,123,129,1200,1250,168 in progress (3) 42inch plows, QA-42A,#1 tiller, 10inch brinly plow, Case Ingersoll 224, 1948 Farmall H, 1950 McCormick W-6, 1952 McCormick W-4. |
The best way to add weight is loading the tires and wheel weights. That is rolling weight. Hanging weight on the back plus body weight adds to the stress on the wheel bearings.
On my 125, I have loaded 10.50s, a pair of gilson wheel weight 65 x2=130 plus my 210 lbs. |
27x12x22 quad tires loaded 145lbs per side
125 wheel weights per side a Johnny bucket weight box full of weight probably 300 lbs and My 190 lbs. this is on my 149 loader. |
my 982 i have 300lbs of wheel weights 300bls of liquid and me 340 it hell up for ten years now.
I've got my 180 lbs plus 80 on each wheel on my 100. I have a feeling we're underestimating what the bearing in the axle tubes will carry.
Mike - Ramsey, MN '65 100 - #126432 Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles "Why buy something shiny & new when you can save something old." |
Although our Cubs are well built, some of them are 50 years old. That's a lot of time for previous owners to do some not so nice things with them.
I'm not sure how that works for the earlier tractors that have bronze sleeve bearings instead of roller bearings. |
Yup Yup the best place for weight is on the wheels!!! Load the tires and put wheel weights on the rims. It saves the bearings a lot and I mean a LOT less stress on the axels
