Old 10-21-2023, 05:19 PM
Dirty Steve's Avatar
Default Been a while....GT2544
Hey folks!
Been a while since I posted because I was out of Cubs. That was until a buddy gave me this unfortunate 2544. He hauled it to me and the price was ah hem, free.
Turns over, no fire yet. Pulled the deck. Owner said it was chewing up deck belts. Found some odd piece of flat metal bolted in near one idler. It will be a slow but hopefully cheap resurrection for the kids to use.
So, I am back down loading manuals and formulating a fixit game plan.
Anything to watch out for on these models? I never had one of these. Tires are oddly scalped hard on outer half of tread.
Old 10-21-2023, 06:26 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Looks like a wheel alignment will fix tyre problem
That odd bit of metal looks like a dodgy fix on the belt tensioner pulley
There was a recall kit back aways for the tensioner most probably out of date now
I have a GT2550 if I can be of any further help
Oz
Old 10-21-2023, 11:01 PM
CubDieselFan's Avatar
Good to see you back Steve. What engine does it have?
Old 10-22-2023, 01:28 AM
Horizontal shaft Kohler Command. Says 21 on the air cleaner box.
Old 10-22-2023, 01:30 AM
Horizontal shaft Kohler Command. Says 21 on the air cleaner box.:beerchug
Old 10-22-2023, 05:59 AM
Justin Soluna is the 2000 series guy.
Old 12-10-2023, 04:50 AM
jsoluna's Avatar
jsoluna jsoluna is offline
This generation of 2000 Series was known for hood failure - exhaust would melt the grille. Otherwise, they are basically the same tractor as the previous generation that had metal side panels.
They have a stout transmission, solid driveline, all of them came with Command twins and 44, 48, or 54 decks. They are a reliable unit with basic maintenance and care. I find they are a very low-drama machine to own.
I would check the steering gear and pinion, make sure a lot of debris isn't packed in there and make sure to grease it. Many people miss this area. It also can cause problems with the forward and reverse pedal linkage if not cleaned out. There is basically a tray that holds debris behind the engine.
http://www.solunagarage.com
Old 12-10-2023, 05:13 PM
Justin,
Thanks for the insight. I won't do anything with it until spring. Hoping just all fluid and filters for engine and transmition. Probably a battery. It does steer mean. That will need a discerning eye to look for wear.
Old 12-11-2023, 06:02 PM
Ozcub's Avatar
In Australia we only got the GT2544 = 44 inch deck and the GT2550 = 50 inch deck
Oz
