Old 07-24-2016, 09:18 AM
Whitie11 Whitie11 is offline
Default 3240 w/ trans problems
this tractor takes off when lightly pressing peddle at full speed it will literally pop the wheels off the ground. I have tore it down to the transmission and jacked it up tried pressing the peddle with it running and in the air it seems to work like it should but when I let it down the stupid thing wants to pop a wheelly it all forward or nothing rev, works fine
Old 07-24-2016, 10:53 AM
Welcome to OCC! Post about your cub in the CCC/MTD section of the site, you'll get more help there.
Old 07-24-2016, 11:44 AM
Oak is the go to guy for 3000 series questions. I'm sure he will be along.
Old 07-24-2016, 01:25 PM
I'm afraid I'm not much help on this one.
Have you pulled the fender pan and floor boards to inspect the linkages? I would also make sure everything is good and tight on all the mounting bolts & brackets on the transmission assembly too.
Has the oil & filter been changed on the hydro yet?
You may need to do the pressure testing as outlined in the service manual if the above are all good.
