Briggs 16HP Vanguard seal - to glue or not to glue?
That is the question... I'm replacing a PTO end seal in one of these and the seal just pops right out when the engine turns over. It doesn't fit too tight. There are no other signs of a problem, like a crankcase breather issue. It's snug when I push it in but I don't have to drive it in. I can push it in with my fingers. Should I put a bead of permatex on it and let it sit to dry? Or do I have a not quite right seal for this engine? I don't want to glue it in if that's not going to work.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower IH Cub Original with deck #2 cart GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck |
That seems to be a common problem with the 16hp Vanguards. I picked up my 1641 about 10yrs ago because the guy thought the block was cracked. LOL Got it for cheap. I found out that seal in question was popped out. When reinstalling it I used Permatex ultra blue and it's been holding. I found the bore the seal sits in to b e on the loose side as well.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
Ok cool. That's what I was hoping. I know there was an issue with the seal size between Koehler series 1 and 2 engines where it was just slightly different. I didn't know if this might be the case with these engines as well. I'll permatex it and see what happens.
I would give the permatex plenty of cure time. I cannot remember what type of Permatex I used. I believe it was ultra blue. Is the seal you are using rubber coated? Wipe a little oil on the lip portion before you install it.
I have ultra blue. It's rubber coated and I oiled the shaft to slide it in. It's installed and permatexed. Waiting for it to cure now.
I would just get a steel seal and use #2 permatex.
102 soon to be tiller machine 108 mower 73 plow machine 169 soon to be mower 122x2 now parts machines Parts 129 149 parts 61 "O" 104 job to be determined |
