Old 12-12-2023, 08:28 PM
athomas's Avatar
athomas athomas is offline
Default 1450 project
Finally getting around to the 1450 I bought about a year ago ! Starting with the hydro gasket to the rear end leak, posting some pics for those that have never done one . I loosened the brake hardware and pulled this one up through the tunnel, afterwards I removed the fender pan for better cleaning and ease of re-installation ! I have done them this way and by splitting the tractor no preference but easier to line things up going back together without the fender pan . Looks like someone tried to use the original gasket and smeared it up with blue rtv gasket maker but guess what, it still leaked ! Also will make a weld repair to the damper spring bracket as it is badly worn !! It's a pretty nice machine tin is all there and in nice shape , maybe flip it in the spring or mow the summer with it while I rebuild the engine on my 109 !
Old 12-12-2023, 09:39 PM
Never seen a 1450 in person but always liked the looks of them.
A bit crazy to think someone would take that apart and glue it
back together instead of buying a 6 dollar gasket. Well at least that's
what they cost when I bought a 6 pack a couple years ago.
Looks like a good project.
Ken
Old 12-13-2023, 08:55 AM
Just be careful some of that crud and crap don't wind up inside where it will raise he!! with stuff.
I ALWAYS clean these areas well before opening one up for maintenance or replacing parts etc.
Old 12-13-2023, 10:06 AM
Graflex45's Avatar
Graflex45 Graflex45 is offline
I need to pull apart my 1450 to replace the gasket in the spring. Thanks for the pics to show I can manage that without splitting it.
Mine didn't leak when I bought it but started when I power washed the crud off the chassis and blasted away the mix of oil and dust that formed a putty and sealed around the pump! The leaking slowly went away as I used it this season and the crud built back up.
1450- 44A deck,QA-36 snowthrower, 42in front blade
70- 38in deck
Old 12-13-2023, 11:44 AM
FWIW:
Most find out the hard way RTV of any sorts has to be applied to a non greasy surface, in order to be effective.
An oil soaked gasket is not that surface.
Glad your planning to do it correctly.
Old 12-14-2023, 07:50 AM
IHCubCadet147's Avatar
Thanks for the pictures. I have a few that need that gasket replaced, including my 1450. It looks easy enough.
