Removing fluid ballast
I'm getting a set of mounted Ags and the tires are fluid ballast filled.
How does one get the stuff OUT...? Is there any way to do this other than breaking the tire down or should I do that anyway in order to clean / dry the inside?
61 and 63 Originals 123 (2) 782D 106, 147, 122 102 parts It's only original ONCE!
Unless they are large farm tires, you can handle them easily, so no need to remove ballast for transport.
Now if you are talking about demounting the tires off the rims for some reason, you can take the valve core out with it @ the 6 O'clock position and let gravity, and the air pressure push the ballast out into a container of appropriate size. |
Hi George, yes, I can wrestle them around, but I just don't want them filled (there's no need).
Tubes?
You are getting a set of ag's already mounted on rims and they are already filled w/fluid, correct?
May I ask why you do not want the extra weight in a set of ag tires?? If you are going to do any type of ground engaging activity such as plowing, cultivating, grading or even mowing on embankments you may want to reconsider as you will probably need the extra weight for traction. That is, of course, unless you are building a "trailer queen" for shows. |
OK, ok, I'll give it a try as is.... I will use it for mowing/hauling on an irregular lawn, so I'll give 'em a go.
Tubes? Who knows? :-) I'll post pix when I get em (monday?)
