What is your favorite modification?
If you did or could do anything to your Cub, what would it be. Maybe a adult beverage holder, Led lights or four wheel drive. Lets see or hear them ideas.
If I could afford it I'd put a diesel in every one of them
I like to keep em running and work them. 1872 (I call her Vera), 782D, 154 Loboy (w/tiller, 3260 deck, and front blade), 3-1650s, 2-1000s, 149, 147, 106, 1810, Farmall Cub, Haban sickle bar (not mounted), No. 2 trailer and several parts tractors. |
So far my favorite mod I've done is making my 2B tiller mount to the 1811. Here's the cool part..... it's quick mount. I can take in off by removing the long belt, and pulling one pin. Literally just takes a minute to take it off.... less than 5 to install. (Cause the belt falls off faster than I can lay down and put it on. )
I had fun adapting a haban sickle bar to a 1641.
Thats a sad looking tractor Sam, you need to shoot that thing and put it out of its misery
Does a sickle bar only lower to level or can it be angled down a bank, say 25 degrees or so?
Randy Cubs: 71, 72, 127, 149, 1440, 2186 and 1864 John Deere 110 round fender John Deere 140 H3 Sears: GTV16 |
LMAO this is what I started with.
Beauty is in the eye of the beer holder. It's ugly but it works sweet and beats running a weed whacker.
I made three different ones that's helped me do a little more work with the cub. First one of my wife's cousins gave me some old sears implements. A disc cultivator, a very heavy back blade and a plow that's missing the coulter. I don't have pics of the plow yet. And I haven't refurbished the disc cultivator yet. I modified the 3point hitch to attach both the blade and disc to work on the brinly hitch. Then I replaced the aluminum nose with a cast iron nose, and put some really bright lights on the rear.
P1030223.jpg P1030231.jpg P1030583.jpg P1030527.jpg P1030530.jpg P1030640.jpg P1030737.jpg
1977 1650 with cast iron lower grill housing, cast iron oil pan, 54" push-snow blade, rear blade, disc-harrow, 44c and 48" decks, Two cultivators, #1 tiller with both extensions, loaded tires, 75' weights and chains, #2 cart. |
One lonely old 1541, 3pt, Brinly plow and cultivator. |
