GT2100 does not recharge the battery.
Hello.
GT2100 (2011) 280 hours. I checked the two wires coming from the stator with multimeter. When the motor is off, there are 4.8 ohms coming from the stator and when the motor is running there is no voltage coming from the stator. Does this conclude that the stator is defective without a doubt? Any help is welcome ! |
The output from the stator is A.C.
Make sure your meter setting is on A.C. |
Positive or Negative ?
Thanks fo reply !
One of the two wires that come from the stator is WHITE and the other is BLUE. Is there a positive and a negative? |
AC is alternating current so no positive or negitive
You should have at least 28 volts AC at 3600 RPM. If you don't have that then you have an issue with the stator or flywheel magnets.
