Vogel Radials.
Sorry if this has been asked before but I didn’t find anything on it. But, has anyone used either the Revo or Riots from Vogel and do they perform better than other non-radial tires? I would be using them on either a stock or stock altered if I decide to go that route.
Or any other suggestions on a pro tire that would be good for a “stock” puller? Our stock class is basically run what you brung and keep it at 4000 rpm or less. I currently run Vm07 on my stock altered so always a option to put those on stock tractor and update tires on that as well. Our club is considering allowing pro tires in stock class so I am just looking for good tire options at this point.
Will proud owner of cub 122,128,70,100,and 682 |
Although at this point I am running a mix of original double cut Firestone’s or Carlisle super lug depending on track so I may not gain much if any with a pro tire. I don’t plan on changing unless I can’t place top three anymore
I know a few people that run them with success. Its one of the few tires I'd like to play with.
scan in the QR code (upper left) or text IHCC to 51660 to follow which shows and pulls we will be attending. |
I agree with Don, I'd like to get a set and try them. I know a few guys that have them and like them.
Thought I’d post an update on this. Was able to get my hands on a set of Riots which are the radial version of a vm11. I will say they seem to hook better and more consistent on varying tracks than my other sets of VM07 and vm08 that are cut by a professional tire cutter. The riots still have the original molded edge on them. I would be curious to test them against a vm11 to see if there is much difference there being they are supposed to be the same tire other than bias vs radial.
