1541 w/Kohler M-18s governor problem
Got my Dad's old 1991 Cub Cadet 1541 [920 hours]when he bought a new tractor. Had multiple problems. Starter would not engage, steering moves 1/4 turn before wheels move, hytran level low , brakes weak. Fixed those problems and the drive shaft cv joints were dry and O-rings gone. Got deck cleaned and painted and degreased and pressure washed the tractor[was never cleaned up before]. put it back together and mowed my grass with it, the governor does not seem to work [slows down when going uphill and when under more load]. looked down the oil fill hole after unscrewing pipe off and saw some white plastic pieces laying around. Was the governor gear nylon? Thanks Jim
I believe it is pieces of the gear
Adrian 2072 (789513) |
That would be my guess too. Surprised it will run. Looks like tear down time.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! |
If it has been overheated the gov can pull out of the case and drop down. It will either chew the gears up or fly apart and one of the rods knock it out the side of the block. The case will have to be split and a new gov gear installed. There is a service bulletin out that tells how to pin the gov so this does not happen but it sounds like it is too late for yours. The gov is about $45 but getting someone to repair it will depend on the shops in your area. The more you run it the better the chance it gets thrown through the side of the block.
Cub Cadet 1811 undergoing restoration Cub Cadet 1862 waiting for paint Cub Cadet 1050 finally got all the parts bought so next in line behind the 1811 for restoration Allis Chalmers 416 Massey Ferguson MF-8 Brinly 10"plow Soil Mover garden tractor dirt scraper Taking donations for a new bigger garage to hold them all |
Where is best place to get M18s governor
Where is best place to get governor for kohler M18S ? I have some Toro HMR 1600 , that were made in 1989 with the kohler MV16 motor [ one has 2760 hours on motor with only fuel pump replaced]. Was the governor changed between 1989 and 1991 ? Thanks Jim
Well I am going for it[governor]
Well I figured those metal weights moving around in the motor might chew it up and I would have to scrap it, and the motor does not run well without a governor. Has anyone else done a governor replacement and have tips on doing it? Pulled motor out today and removed tins. That's all for today, will pull clutch off tomorrow and start splitting it to see the damage. Wish I had known about the governor problems when I had the motor out on the bench the first time. Have found governors on e-bay and on amazon and kohler site[$45.25 + shipping]. Thanks Jim
