Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 06-22-2017, 07:43 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Default What donors for a 1872 repower.
Okay I have 1872 with a M18 engine that I don't trust. I helped my brother-in-law repower a 2072 with a motor from 2206. We are very pleased with how things worked out. So now I'm thinking of using 20-23hp Kohler. What machines should I watch for to get a donor engine.
Old 06-24-2017, 08:41 AM
This was our donor. I don't know how a 500 hour tractor can be so bad. Yes I do the guy used a power washer to keep it clean and destroyed it in the process. Good thing we only wanted the motor and 15 minutes from home.
Old 06-24-2017, 09:56 AM
Inactive Member
Cub Cadet Tractors with a Kohler Command 18:
2185, 2186, LT2042
Command 20:
2084, 2206, 2518, GT2186, GT2544
Command 22:
2284
Old 06-24-2017, 09:59 AM
jimbob200521's Avatar
2185, 2186, LT2042
Command 20:
Command 22:
2284
Hey now, a 2284 should never be a donor machine!
-Ryan
Old 06-24-2017, 01:11 PM
Don't even dream of using a 2084 or a 2284 as a donor. You can add the 1863 it also has a CH18.
Old 10-02-2017, 07:16 PM
jr1983 jr1983 is offline
New to forum and anything newer than a IH built cub. What does a 2284 have to over other than being 22 HP? Just wanting to learn.
Old 04-11-2019, 10:42 PM
nophun nophun is offline
This is usually your best bet, the 2000 series don't seem to weather well and look like to one you posted. I see them often in my area for a couple hundred dollars or less.
The best argument that I can come up with for the CH series is that they are still current. I too have an 1872 which I am repowering with a CH18 this summer; engine plate, driveshaft, wiring and you're up and running.
Old 06-30-2023, 08:23 AM
TheGrinch TheGrinch is offline
Did the original poster finish this?
I have a nice 2072 that I paid too much for and the M20 has burned exhaust valves with 1100 hours.
I have a donor engine from a 3235 (CH23S) but the PTO uses a belt tensioner and I need to utilize an electric PTO. Can some of you please recommend what clutch will work on this 1-1/16" shaft size crank? The original pulley on the M20 is 4.5 inches.
Any other advice for the swap would be great also.
Thank-you
2072 owner
Old 07-02-2023, 06:46 AM
Call Xtreme Outdoor Power Equipment
3705 95th Ave. N.E.
Blaine, MN 55014
Office Number: 561-852-1010
Email:
sales@xtremeope.com
techsupport@xtremeope.com
And see if they can hook you up.
Old 07-16-2023, 06:02 AM
Thank-you!
2072 owner
