2166 hard to start - adjust carb choke plate!
I have a 2166 that has been hard to start for a long time. It turns over, but takes a while to start. Once started, it ran great.
From sources like this forum I tried lots of things: > Checked spark- looked good > Checked fuel flow - fuel pulses out of the filter when turning over > Checked choke linkage - fully closing > Cleaned carb It would still take 10-20 seconds to start. Then I noticed the kohler carb rebuild instructions included a short section on adjusting the choke plate. 'To align choke plate, insert a 0.010 in. shim between the top right edge of the choke plate and bore.'I loosened the carb choke plate screws, adjusted the choke plate and re-tightened. It starts much quicker now!! This adjustment solved a nagging slow to start issue for me. Maybe this could help someone else with a kohler that is slow to start. |
That is good info for someone. Thanks for posting that Bob.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
