Front hydraulics on a 982....Part 1
I needed front hydraulic connections on my 982 to run different options, since my 982 only had a single spool valve I picked up a 3 spool valve from Epay for around $40.00 last summer that came off a John Deere. I was going to modify a twin lever for a two spool valve but it must have come off a 782, it was 3/4" too short so I had to modify the single lever that came off the 982. I bought some bushings and flat stock from tractor supply and modified them a bit and tacked everything together. I had a striped 982 frame in the garage and used it as a test dummy to fit up the valve, worked out pretty good. I still have to modify the valve mounting plate and plumb up the hydro lines and connectors to the front as play money allows, that will be part two.
Let me know when you are gonna buy your hoses, I want to buy stock in Parker that day!!
Looks great!! |
Looks great!
Nice job!
Thanks guy's, now that I know it works I can start the finish mount and think about plumbing. I really like the 3 spool, as looking at it in the picture the spool on the left has a "float" position which will work good on one side of the front. It also has a power beyond port for at least one more hydraulic valve option in the future, who knows ?
planing ahead never hurts.
127 - 48'' deck + tiller. 1512- 46" GT deck & bagger 1872- 60" Haban 1772 turbo diesel- Iron rear + KW loader + backhoe + 3 point. Case 580CK Ford 850 International TD-8E |
Think I'd go tube for that job.
mmzullo: Sure thing.
Sam: My thought's also. |
Great job! Looking forward to your updates!
Nice job! The lever configuration looks well thought out
