Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 01-08-2021, 05:48 PM
Jaystang97 Jaystang97 is offline
Default Engine oil
Changing the oil in my 1810 today and it is super thin and smells like gas! Any ideas of how gas could get in besides it being put in there which I didn't. I inherited the tractor a couple months ago and im going through it doing maintenance.
Old 01-08-2021, 06:09 PM
Angry
Muffler is dripping with gas as well!
Old 01-08-2021, 06:18 PM
mortten mortten is offline
Fuel pump leaking fuel into crankcase.
Doug
QA-36A
42" blade
Old 01-08-2021, 06:29 PM
Not to sound like fool im assuming the fuel pump would be under the T where the lines connect? And had just cleaned the carb any chance a stuck float would allow it to leak in?
Old 01-08-2021, 06:49 PM
RLause's Avatar
RLause RLause is offline
If the float leaks, the gas runs into the cylinders past the rings and into the crankcase
Richard
Old 01-08-2021, 06:58 PM
Don't run it till you address the problem AND change the oil!!!!!
If you messed with the carb. either you have crud under the needle valve or did something wrong.
Start at the carb first, many times removing/installing the fuel line induces crud under the needle valve.
Also it will smoke like hell after you repair it and start it as the fuel is burning out of the muffler.
Running it without changing the oil, will do damage to the engine
