Old 03-08-2014, 11:49 AM
duryea21's Avatar
duryea21 duryea21 is offline
Default Subsoiler / ripper
Made this from an old Simplicity walk behind plow, it is not a Brinly!! Hope you like the pics
Old 03-08-2014, 11:51 AM
duryea21's Avatar
Old 03-08-2014, 12:05 PM
Looks good, let us know how it works.
Old 03-08-2014, 03:15 PM
Very nice work!! Hey sam, do you think a fresh 12hp cub would pull an attachment with 3 or 4 rippers, or chisel plow tines like that on it???
Old 03-08-2014, 04:49 PM
Sorry but I can't answer that for you. Maybe one of the guys that has plowing experience will chime in but I think you may be traction challenged.
Old 03-08-2014, 04:59 PM
Nitro's Avatar
Nitro Nitro is offline
That is really nice, like the adjustment crank. You won't find anything like that at Tractor Freight.
Philip
1450, 1015, and a pile of parts.
Old 03-10-2014, 01:43 PM
clint clint is offline
I don't think you will have any problem getting it into the ground, now controlling how far it goes into the ground you may have a problem. It doesn't look so much like a subsoiler, more like a layoff plow or something like that. I'm not sure how good a GT will pull it either I have seen videos of GT's plowing however here in Georgia red clay I gave up on dreaming of plowing with a GT. Below is a picture of a single subsoiler the only place I have ever used a subsoiler was in a pasture to create water retention.
1440
1282
1604 cast rear/transmission (582)
149
1450 (2)
JD317 54" blade
JD318
Ford 3600
Old 03-10-2014, 10:05 PM
john hall's Avatar
I think it will go in the ground as well. I've got a single shank subsoiler I made by using the shank from a Taylor-way subsoiler designed for a Farmall M and building a 3pt hitch to fit a 90hp tractor. The shank design on it is about the same. I can drop it in at least 18". I'm curious where the hardpan on a garden spot would be, maybe 6-8" if it has been continuously worked with only a tiller? I really think this will improve how well a tiller and disc perform. Should improve yield on sweet corn too!
Old 03-11-2014, 12:10 AM
I guess we will find out when he sticks it in the ground whether it will work or not. It really all depends on how deep he wants to go. That is scarifier shank off of a box blade, and I've tried to use those for ripping before. They weren't curved enough. Went in about 4" and that was it, and that is with a BUNCH of weight on it. It's all about the curve/angle. The hard pan is in the same place it will be in any other location in his area, being a garden doesn't change that. I don't know where that is in PA. In the part of Ill I'm in, the hard-pan is about 12"-14".
Old 03-11-2014, 01:30 PM
john hall's Avatar
You're right about the hard pan. I should have been a little clearer, meaning the ground should get quite a bit tighter once you get beyond the zone normally tilled, but certainly not to the point it will fracture and lift when ripped.
