Old 05-22-2011, 10:01 AM
oldmil oldmil is offline
Default 1015 Cub Cadet Blade problem
I have a 1015 Cub Cadet that the Blade keeps coming loose on the right of the deck where the grass is discharged. No matter how tight the blade is on it will come loose after a couple rounds of cutting grass. I have new blades on but this still happened with the old blades on. Any suggestions?
Old 05-22-2011, 11:28 AM
Looking at parts look up it looks like they use a stanard washer and nut. Part numbers are 712-3018 Nut, Hex, 3/4-16 GR8 and 736-3014 WASHER-FL I would go to my local bolt supply company and replace the nut with a locking type nut. Take your old nut with you and let them know what you need it for and they will hook you up. Should be $3-4 each and I would do both sides.
Old 05-22-2011, 01:17 PM
Thanks Duke. I will try that.
