I thought I'd throw this out there to see how you guys do it. I raise the front of my 1000 with a floor jack, position a jackstand, and commence to scrape the underside of the 44A with a sturdy putty knife. I do this once a month and sharpen the blades if needed. The wet grass sure causes build-up and the deck definitely works better when it's clean. A clean 44A is a happy 44A.
I of course do it the hard way, LOL. Remove the deck and strap it to my 2 wheeled dolly then scrape it down, Remove the blades with electric impact and sharpen them up. Pump in a few strokes of grease in each spindle and put the deck back on. In fact I did this about two weeks ago or so when I had to remove the deck to plow the garden with the disc.
![]() Quote:
![]() Quote:
I take deck off every 2 weeks for cleaning, and monthly spindle belt cleaning/ blade sharpening. I grease spindles before every run, so it generally works in fresh and warm.
104 to 127 conversion with dual 6x12s, hydraulics snow/dirt plow 1200 Quietline 44" mower QA-36 snow thrower |
On my 48" deck for my 123, and this was several years ago since it has been retired from mowing, I sprayed my underside of my deck with automotive underbody spray (cover blades and spindles of course), and I never had a problem with buildup from that point on. I have thought about spraying the underside with the rhino liner spray for truck beds, but never had the time to do so for my other decks. They also make a slick spray (sorry, the name escapes me) that you can spray on the underside of your deck to prevent buildup and some guys use it on their snowblower chutes, too. I've never used this spray and don't know anything else about it.....just a thought.
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
