Old 06-27-2011, 07:32 PM
CaptMax's Avatar
CaptMax CaptMax is offline
Default Bought a 3 point - quick question
I am in need of the dimensions for the lift rod spacer on my 3-point hitch. This is item # 711-3073
This is the only part holding me up from installing my tiller and hitch. If anyone has the measurements I would greatly appreciate it. Thanks!
CaptMax
Old 06-28-2011, 05:27 PM
CaptMax's Avatar
Ok, If anyone has a good picture of this part can you please post it?
I'm sure I can fabricate one if I know what it is supposed to look like.
CaptMax
Old 06-28-2011, 05:56 PM
Let me see if I can help you out Captain. I know for a fact the OD is going to be 3/4". I will try to get you the ID. I know the bolt that I put into the lift rockshaft threads was a 3/8" bolt, but I will double check.
Old 06-28-2011, 06:15 PM
CaptMax's Avatar
Sounds good and "Thank-You" DX3, This is the last part I need and then I can post some pictures of the 3 point and stainless sleeve hitch I've installed. I just need to fab this bushing to make it all work.
CaptMax
Old 06-28-2011, 06:23 PM
The ID is 1/2". An 11/32 socket I had fit perfectly into the bushing. It measured .509 or 1/2". I lost the correct bolt to use in the bushing and am using a standard bolt till I can get another. There is definitely just a bit of slop with a 3/8" bolt thru the bushing.
11/32" socket
Socket measurement:
Wrong Bolt
3/4" OD
Old 06-28-2011, 08:08 PM
CaptMax's Avatar
Thanks DX3, I will get one turned on a mill my friend has and finish installing it.
This is how it looks at the moment, I also just finished restoring my snow plow so that is why it is mounted this time of year. I sure love my Cub!!!
CaptMax
