Old 06-28-2011, 01:20 PM
j.m.jackson j.m.jackson is offline
Default 1872 - Standard SGT rear end...
So i was browsing the local CL and I came upon an 1872 that the owner was selling for parts. He did disclose that it 'threw the driveshaft'. We all know what that means.... a busted AL rear end. I called him, and he was about 4 miles down the road from me. I looked it over in the pouring rain, made him an offer, and he took it.
I finally pulled the rear this weekend, and pulled it apart last night to survey the damages. Here is what I found:
And everything was put together with red loctite.. and the rear end bolts were WELDED to the frame. Yes, WELDED.
Old 06-28-2011, 01:26 PM
It's amazing what PO's do to the cubs. Congrats on your 1872.
Old 06-28-2011, 01:44 PM
That's a ton of crud! What's your plan with it? Are you going to try and get another rear end? Cast or Alum?
I think I'm just going to drop a CI rear end in and call it done... unless someone has a line on a local AL rear and a hydro coupler for a super, with the splines. When it kicked out the driveshaft from the rear end pitching back so far, it knocked off one of the ears on the hydro end of the driveshaft coupler, and they are $125!
Old 06-28-2011, 01:48 PM
Originally Posted by j.m.jackson View Post
I think I'm just going to drop a CI rear end in and call it done... unless someone has a line on a local AL rear and a hydro coupler for a super, with the splines. When it kicked out the driveshaft from the rear end pitching back so far, it knocked off one of the ears on the hydro end of the driveshaft coupler, and they are like $125!
I spoke to Rich Patton this morning about dropping a CI in my 2072 and he was telling me that the supers are geared diffrently then the GT so you'ld have to swap the internals between them. He wasn't sure how the gearing would effect the super if you just bolted on CI rear up and swapped hydro pumps.
Just last week I had to spend the $$ for that rear coupler so I know your pain!
Old 06-28-2011, 01:50 PM
Matt has a write up on the rear end swap. I'm sure he'll post on this thread and help us both out.
Old 06-28-2011, 02:06 PM
I think it will, but I'll have to use a non-super pump, so my max ground speed will be faster due to the 26" tires instead of 23". I really would like to swap over the internals, but I don't think I have the tools, or the shims, to properly setup the AL gears in the CI rear end. Otherwise, it would be a no-brainer, as I have great AL internals, and a good CI rear end.
Old 06-28-2011, 02:17 PM
Not sure if that can be done or not. Why would you use the non super pump?
