Old 08-10-2011, 07:50 PM
jbollis's Avatar
jbollis jbollis is offline
Default cab refurbish thread
I started to work on the cab today. I am going to restore or refurbish this and thought some would like to see the steps I take, so I will periodically be updating this.
I found it to be in worse shape then I had thought it was. Nothing That makes it not worth fixing, just more work then I was planing. It has some pretty bad rust issues. I got everything but the inside of the roof wire wheeled down to bare metal. The white paint on it is just not wanting to come off. I sprayed it with some oven cleaner and will let it set till tomorrow. That should help it come off easier. I think I will just give a full coat of por-15 then prime and paint on top of that. The por-15 should keep any of the rust from coming back.
I also drew up a print for my buddy that owns a sheet metal shop, so he can cut and bend the piece that I am missing that mounts everything to rear fender. This cab is not for a cub cadet. It is about 3 inches wider then the fenders. I had to get creative with the mounting piece, but it should look good when it's done.
Found some stress cracks in places. Both sides just below the windshield. Also found 2 cuts that po must have done for some reason. the cuts are on the lower part of the rear section. I can't even think of why they would have done that.
This is what I started with.
Sold everything but one.
Old 08-10-2011, 07:52 PM
jbollis's Avatar
And this is where I am at now. The only thing I have done at this point is to disassemble and use wire wheel to remove the rust and paint..
Old 08-10-2011, 08:56 PM
Looking forward to watching your progress
Old 08-10-2011, 10:18 PM
Same here!
Old 08-10-2011, 11:59 PM
Same here!
Add me to the list!
#3!
Old 08-11-2011, 07:34 AM
jbollis's Avatar
if anyone knows were to find replacement parts for these please let me know. I will be needing to do something with the wiper. I will either need a motor or hand crank. I might possibly need the wiper arm and mounting post to.
Anyone with some pictures of there wiper setup please post them so I can start figuring what I will need to do.
