Old 09-13-2011, 12:43 AM
WV boy WV boy is offline
Default M-18 in my 782..??
Has anyone swapped a M-18 into the 782? If so, can you give me some help? I'm having a time getting the ignition switch/ignition to work.
Old 09-13-2011, 06:38 AM
The ignition switch for a 782 and the one needed for a M-18 are totally different.
There are two different wiring diagrams for the 782 model. depending on the Chassis Serial Number. If you supply your serial number, I'll send the correct wiring modification for your tractor.
Old 09-13-2011, 07:48 AM
FWIW
In a nutshell:
The m-18 requires a ground position to kill the mag.ignition.
Your oem switch provides power to a ignition coil or no power to the coil to stop the engine.( M-18 does not use this system, it has a mag)
The start terminal will remain the same.
There are several ways to go about this, one involves a simple relay,
and several articles here relating to this, just use the search feature.
Old 09-13-2011, 07:52 PM
ajgross ajgross is offline
Inactive Member
let's see if I can link the diagram for the wiring change.
Old 09-13-2011, 08:08 PM
brentwd's Avatar
brentwd brentwd is offline
My 1712 has a M18 and to start the tractor you turn the switch on and it has a toggle switch for the mag. Vice versa to turn it off. Seems to work fine.
Old 09-13-2011, 08:12 PM
Vince_o Vince_o is offline
With help from Aj, short bed, and someone else, name has slipped my mind, engnieer for cat, I have one in my 582 and you all have seen the command going in Dannys 482. I wired mine like Ajs dia.
