Old 08-10-2009, 08:24 PM
angry1 angry1 is offline
Unhappy K241 Timing issues on a 109
I found the breaker points with out an issue for a K241 motor, I looked on the flywheel for the S or SP mark and could not find a mark. Now I am looking for the bearing plate or blower housing where is this located? because I cannot find it. I know it's in front of me and on the engine but for the life of me I have no idea where it is.
Help a brother out and point me in the general direction so I can change the points and condenser and get it running better again.
Old 08-10-2009, 08:40 PM
RPalmer's Avatar
RPalmer RPalmer is offline
If you want to try it without a light and be done with it... here's how.
Remove the points cover. Loosen the screw holding the adjustment. With your left hand turn the engine by turning the starter pulley.
Notice when the points start to open and where the engine pulley is. Keep turning until they almost close. Note where the pulley is.
Now turn the engine back halfway from where they started to open and almost closed. This is your gap point. Set the points to 0.18 and tighten. Recheck your setting after you tighten the adjusting screw. Sometimes they move. Usually to the closed side.
If you make this setting perfect your tractor will start on the first or second revolution.
Old 08-10-2009, 10:42 PM
FYI...gapping the points will almost never make the timing be in the right place. I have had tractors that would barely run with the points at the manual specification of .020". I've had smooth running occur at gaps like .011" or .028" or so.
The bearing plate is the aluminum plate that is bolted to the block under the flywheel. The blower housing is the piece of sheetmetal that surrounds the flywheel. There's a roughly 3/4" hole in the blower housing on the right side of the tractor. Shine a bright light through the hole as you rotate the flywheel. The marks are usually hard to see. When you find them, wipe some paint or white-out in them so you can see them. Then you can use your timing light, or my preference, an ohmmeter, to set the timing.
Old 08-10-2009, 11:41 PM
RPalmer's Avatar
What I wrote below is how I have done three engines. Two K241s and a K301. All three start before two revolutions of the engine. I guess this is a case of your millage may vary . But then again i knew points and dwell before electronic ignition was invented.
Old 08-11-2009, 03:31 AM
Thanks for all the help....... now I know where to look and get the job done I figured as long as I am replacing the points I might as well check the timing. Thanks for all the pictures that helped out as well, as how others have done it.
Thanks once again!!
Old 08-12-2009, 05:28 PM
ajgross ajgross is offline
Inactive Member
To use a ohm meter, you connect the ohm meter to the points. There should be no reading. You then turn the engine in the direction that it turns normally. You then need to look inside the timing hole and set your points so that you just start to get some resistance when the timing mark is at "S" or "SP". I think the "T" marks Top Dead Center. This makes sure that your spark is firing at 20 degrees before TDC. The push rods that open the points wear over time and the .020" isn't always correct. You use a ohm meter because without one, you can't see the actual point where the points begin to open.
AJ
Old 08-12-2009, 05:42 PM
Yep, that's how I do it...AJ beat me to posting the explanation though...
Old 08-10-2009, 10:44 PM
67hydro's Avatar
67hydro 67hydro is offline
Hey angry,hers a couple pics!!
Here is the plug in the bearing plate,difficult position to get to,the Starter generator is kinda in the way!!The bearing plate is silver in the picture the plug looks orange in this picture.
In this picture the plug is behind the starter generator bracket bolt farthest away or to the left in the picture.Kinda hidden behind the bolt in the picture.
this is the timing marks on a 7 horse,I DO NOT Know how different they are on the 10 and 12 ect.In my book it also says s or sp but there is a t inprinted????
Here is a picture of the bearing plate with the flywheel removed and fly wheel cover removed,this is the drive shaft side of the engine.
Here is a picture of flywheel cover,flywheel and bearing plate!!All loose on this particular Engine.
I cant see how to use a timing gun without removing the starter generator although Ive never set the timing that way!!Maybe someone can give you tips on that!!
Good luck
Jason
Jason Davis
Old 08-10-2009, 10:49 PM
67hydro's Avatar
Im sorry I dont have the ability to put arrows on the pictures!!
Matt,
Please explain the ohm meter timing setting,seems like possily it would be easier than getting a timing light in there!!!
Jason
Jason Davis
Old 08-10-2009, 10:51 PM
67hydro's Avatar
Angry,
Are you sure its the timing??Or Are you just doing a maintenance on it and want to replace these parts and Re-Time it??
Just wondering.
Jason
Jason Davis
