Old 09-28-2011, 07:00 AM
Default Is my bracket going to be too weak?
I started on my 882 starter/glow plug upgrade but I'm concerned about a PO mod. They cut the engine bracket and I will need to drill a hole for the battery terminal but is this bracket going to be weakened too much. Should I pull it out and weld a piece back in?
Old 09-28-2011, 01:08 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
I would think it would be ok, but you have to pull the bracket off anyhow to do the starter mod, so you might as well weld a piece in to make sure there are no issues. That's what I would do if it were me.
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
Old 10-03-2011, 10:09 AM
I had to order a new manifold because the old was broken and drilled the hole for the upgrade with the bracket in the tractor. I will pull the bracket and weld it up but not until I hear the engine run. My 100% new China starter came last week and I installed it yesterday, replaced the fuel lines, filters, upgraded glow plugs and washed all the grease and grime from it. I hope to have it running this week.
Old 10-03-2011, 10:55 AM
Someone's been busy, looking good. How about a vid of that thing starting up with all the new upgrades??
Old 10-03-2011, 11:24 AM
Looking great Todd! I'm surprised you had the energy to work it after all that sod Sat.
Old 10-03-2011, 11:54 AM
Looks nice, Todd! I know, you're looking forward to hearing it run.
