Old 10-10-2011, 09:48 AM
Default Chains on a Super Garden Tractor??
Can you put chains on a Super Garden Tractor??
It looks like the chains will hit the fenders?
I was wondering if my tires are "ballooned" due to age or possibly being too low of ply rating (they might be 2 ply).
If I put on 6 ply 26x12x12 tires will they be flatter across the tread giving me more tread-fender clearance?
The tires were originally tubeless and loaded with CaCl by the PO, I drained each and went to tubes as the machine aged and developed flats.
I run about 10 psi.
Or will my SGT remain a Shed Queen when it snows??
Old 10-10-2011, 11:19 AM
You can put chains on them.
Old 10-10-2011, 05:34 PM
BThein's Avatar
BThein BThein is offline
I have been running a set on my 1872 they are close but clear just fine.
Bob
Old 10-10-2011, 07:04 PM
My Chevrons don't seem to fill the wheel wells like those turf tires do.
Old 10-10-2011, 07:07 PM
CCSuperMan's Avatar
That's one nice looking tractor
Old 10-10-2011, 08:21 PM
Thanks CCSuperMan, I do have to give the credit to aagitch for getting it like that tho.
Old 10-10-2011, 10:45 PM
I second that!
Old 10-10-2011, 08:22 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
Chains will fit on it just make sure they are tight. mine tire looked the same way but i had a blow out so i put a set of 6 ply and they a flater
Old 10-10-2011, 08:39 PM
Iowa Farmboy Iowa Farmboy is offline
I installed about a half inch of washers under the fender mount by the battery. It leveled the fenders and gave more clearance for chains.
Josh
1989 SGT 2072 (restored)
60"Haban Deck, 54 "Haban Blade, 48" Cub Cadet Tiller, 12" Brinly Cat O plow, 48" Cat O landscape rake
Cub 128 with creeper and rear PTO with reverser(next project)
IH built 682 and 782 that will combine to make one
