Old 10-17-2011, 06:28 PM
rsierra1025 rsierra1025 is offline
Default Gasket Suggestions/pulley replacement
Hey all,
I'm trying to clean up the Cub and accessories. In a nutshell I have a father-in-law that can't follow directions and decided to go his own way in assisting my project. Anyhow, long story short he decided that he "HAD" to take the drive shaft for the snow blower apart. Thankfully I rescued the cap but don't have a clue what to use for a gasket. I have been everywhere looking for a replacement, the Cub dealer said they couldn't get anything and didn't even offer a suggestion. I went to the power train place in town that builds drive shafts and rack and pinion stuff. They didn't even have anything. Thankfully he had a suggestion although he said it was "OLD SCHOOL"....just find some leather (old shoes or belt) and cut it to the size I need...maybe a couple thick. I think it's my only option unless you have something else.
Also, when I bought the tractor one of the pulleys was broken. Anyone have somewhere they order those heavy cast replacements from. If so, what number? The Originals on Ebay are a bit spendy. I just want to make sure I get the correct replacement for the belt.
Thanks in advance,
Randy
Old 10-17-2011, 06:42 PM
CHWNY's Avatar
CHWNY CHWNY is offline
You say you saved the cap? If that is what screws onto (or otherwise acts as a retainer for the gasket) the female side of the drive shaft, than you can cut an "O"-ring from heavy 1/4"-3/8" thick felt. That is what was used on the rear axles of 8n fords and GM torque tubes.
Old 10-17-2011, 06:48 PM
I don't believe there is any kind of gasket in there, just the metal cap.
Motion Industries and probably also McMaster-Carr have cast iron pulleys that will work.
Old 10-17-2011, 06:49 PM
CHWNY's Avatar
OH the pulley! Try Tractor supply they have a good selection, I think you can order online if no local store. I use a local industrial belt/power transmission supply. Good luck
Old 10-17-2011, 08:36 PM
Default THanks.
I'll look into the felt.
We do have a tractor supply up in Ankeny. I tried Shoppers supply which is similar to TS, they had some pully's but they didn't seem very heavy.
Thanks for the help.
Old 10-18-2011, 09:32 AM
FWIW: when you slide the drive shaft together, make sure you have the yokes aligned,so as not to cause excessive vibration/wear.
Old 10-18-2011, 09:38 AM
Default Thanks
George,
Thanks for the tip. Never would have thought about that...
Old 10-18-2011, 06:55 PM
CHWNY's Avatar
If you go to TS they might have pulleys in two places light duty by the belts or wheels and heavy duty ones in the tractor parts section, these have weld on hubs and you can make up most any combo. you'd need
