Old 10-18-2011, 09:35 AM
rfrank's Avatar
rfrank rfrank is offline
Default 1450 control Valve Spool Screw
I was mowing yesterday and when I went to lift the deck the handle came all the way back. Hmmm I pulled it into the garage and the hydro fluid was running everywhere. fortunately I only drove it 30 feet. Seems as though the screw for the bottom of the spool vibrated out and has gone missing. After I replace the O rings does anyone know what a suitable replacement screw would be?
Old 10-18-2011, 11:46 AM
Here is a image of the Control Valve. Which part are you referencing...??
Old 10-18-2011, 12:05 PM
rfrank's Avatar
#7 the valve body looks more like the 149 (flat) assembly. The spool likes like the lower one in the picture. The screw appears to be around the 8-32 size but I am unsure as the length? The end of the spool is threaded and thats what keep the spool from exiting the top of the valve when one pulls the handle. thanks for the help.
Old 10-18-2011, 12:12 PM
rfrank's Avatar
This more closely resembles the valve body
http://www.rfhoutzandson.com/Product...0-62c95c76e81b
Old 10-18-2011, 12:45 PM
rfrank's Avatar
Here is a pic of the end of the spool.
Old 10-18-2011, 03:59 PM
The imaged valve is what was used on the 1450. Now if some has modified the Control Valve and used something different. Then I don't know how to help you.
The Spool Screw is IH-674491-R1 which is NLA from Cub Cadet. You may have to look around salvage yards to find one. Or, replace the entire spool valve.
The 149 used the same Control Valve as the 1450.
