Looking for axle bushings 941-3005 for the 1872, 2072 tractors. I see they are NLA. Anyone have dimensions for them as I can make them at work. I just can't have the tractor down right now to remove and measure. Also, are they made out of brass or bronze? Mine have a lot of side play in them and I assume thats not normal. The tractor has 860 hours on it and I've always greased them monthly. Thanks.
Could you post a pic of what you are talking about .The 1872 is supposed to have bearings in the axle tubes not bushings I know the original had them but thats about it.
Jed Proud to be a FFA member Westmoreland,TN Chapter 1978 Cub cadet 1450 IH Hubcaps 1975 1650SGT Work In Progress 1974 cub cadet 129 with sleeve hitch/spring assist 1974 108 (Mint) #510358 brinly 12 in plow,disc,8 in plow ,2 42, 2 44A ,50A DECKS #40 boxblade,can`t keep up with the rest lol ![]() ![]() ![]()
What did you grease??
Not the wheel bearings, cub calls it steering knuckle assembly. Sorry for the confusion.
Again, pictures would be most helpful...
I think he means the bushing where the spindle goes through the cast iron axle and rotates for steering.
If mine were worn, I would measure MINE before machining, to compensate for wear. |
You can get them though a local bearing place. I got mine at Buffalo Bearing. They are brass with a steel outer casing and the a split. There are two a side. I don't remember the exact size. I'll look and see if I find a old one, then I can measure and show you what they look like.
Number 2 in picture. Part# 941-3005.
Rob that should help a lot!
I've edited your post and changed the title to front axle to clear things up a bit. |
I've got a set here along with the whole axle !!
![]() I could either part 'em out or measure and make them . Either or .
