![]() I'm in the process of buying a 1450. Is there any thing special I should know about them? Any secrets I should know? ![]() ![]()
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10:
You are looking at a Quiet Line series, the series known for ISO mounts that usually are bad if they are original. Not a big issue, but the motor has to be removed to fix them, and if they are bad, more than likely the Drive line, "drive shaft, bushings and flex discs will need replaced too. If the motor can be moved around by hand side to side the ISO's are shot. More than likely you will have to repair the trunion on the hydro, not a bad thing if you can weld or have a buddy than can. With these minor issues fixed, they are great tractors just like the others. Also there is a mod called a cradle mod. Do it while the motor is out, it will reduce the ISO deterioration problem.
Here is a list of links you will need to visit and download. Quiet Line Links: Download and print all the manuals; Carb Rebuilding: http://mgonitzke.net16.net/tools/carb_rebuild.pdf ISO mount and snubber: http://www.onlycubcadets.net/forum/showthread.php?t=7 Hydro Filters: http://www.onlycubcadets.net/forum/showthread.php?t=12 Ignition Circuit: http://www.onlycubcadets.net/forum/showthread.php?t=27 Ignition Coil: http://www.onlycubcadets.net/forum/showthread.php?t=11 Spark Plug Chart: Use Autolite: http://www.onlycubcadets.net/forum/s...ead.php?t=4638 Static Timing for new points: http://mgonitzke.net16.net/tools/static_timing.pdf Chassis Service Manual: http://www.onlycubcadets.net/forum/s...ead.php?t=4644 Kohler Service Manual: http://www.onlycubcadets.net/forum/s...ead.php?t=4646 1650 Operators Manual: http://www.onlycubcadets.net/forum/s...ead.php?t=4670 PTO adjustment: http://www.onlycubcadets.net/forum/showthread.php?t=30 Wiring Diagrams: http://www.onlycubcadets.net/forum/showthread.php?t=22 Cradle Mod: http://www.onlycubcadets.net/forum/s...ead.php?t=4630
Not to be a wise guy, but your signature line shows you own a 1250...
So you know the in's and out's of the series. Take your 1250 and put a 14hp in it, add a hydraulic lift to replace your manual one, and you've got a 1450. |
im getting a 1450 from our hiredhand on our farm. he ows me $75 for an engine i sold me. so he said he will buy me the tractor.
