Old 01-05-2012, 03:13 PM
becullum becullum is offline
Unhappy Engine won't start
My Cub 100 ran fine then silly me decided to clean the carb. After cleaning the carb the seals leaked so I took it in and the dealership said they should put in a new carb kit. I said OK, but now I am not getting any fuel to the engine. I think the throttle/idle may be set wrong. I bought a new battery, put in a new plug, I even can see the fuel sitting in the fuel filter, but just won't start. Anyone know how to set the screws on the carb?
One more question. The seal in the bell float housing leaks and I haven't been able to find one. I cut a new one out of gasket material, but it still leaks a bit. Anyone know where to get a new one? Thanks for any info.
Old 01-05-2012, 04:45 PM
Did you look here....??? .... Service Manual
Look at page 6.14.
Old 01-05-2012, 05:11 PM
Wow you have everything on this site. Lets see if I can get her running when I get home. Not sure what else could be wrong with it since it ran before messing with the carb.
Old 01-05-2012, 07:59 PM
MOturkE's Avatar
MOturkE MOturkE is offline
It could be a sticking needle. The float is raised by the fuel and causes the needle to plug the small port where the fuel enters from the fuel line, it's possible that the small rubber tip on the needle has become indented. Also, your float may need adjusted. It might be floating too high and jamming the needle into the port. Check the manual for adjustment info.
I've had a sticking float problem a few times now. Pretty easy to deal with, really.
Proud to own a 1965 Cub Cadet 122.
