Old 01-17-2012, 10:17 AM
jkier's Avatar
jkier jkier is offline
Default Swapping elect. lift for hydro
I have a spare NF add-on hydro lift that I've been contemplating adding to my 147, replacing the factory electric lift.
Just from a quick glance I'll seem to need to add a pulley to the drive shaft to drive the pump.
Anything else I should expect to need?
Thanks,
Jeff
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
Old 01-17-2012, 11:32 AM
cub123's Avatar
cub123 cub123 is offline
Your going to have to drill holes to put it on. The 147 has a pulley on the flywheel, but if you run something from them the belt will rub on the screen, so like you said, you need a pulley, but don't mount it on the driveshaft, as it will ruin the rag joint and stuff with a belt pulling on it sideways. Looking at my dads it should fit otherwise, but I'm not 100%
Old 01-18-2012, 12:48 PM
jkier's Avatar
Saw the pulley inset into the screen, need to work on a bracket to hold the pump itself.
I'll have to take a close look at this.
I may just swap the electric lift from the 127 to the 147.
(The 127 has an upgraded elec. motor)
Maybe save the pump for the 100 I'm searchin for..
