I'm watching Sugarmakers thread and was prompted to do an 1A I picked up but it turns freely. I shot bolts and external moveable parts with WD-40 and moveable parts are (and were) all free. I pulled the pins and thought maybe I shouldn't open this up. I was concerned about inside because of it's age even though there was no sign of leaks. I bought this last summer and have not used it yet and have no idea how the PO treated it. I want it to look nicer which just means paint but more importantly I want it to be a worker. The bearings are sound. Since everything moves freely, should I tare it apart just to change the lube because of it's age?
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights 72, Serial #231093, K161S Serial #C281773, 36" deck 149 & Original Yard art 1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch 1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted 123 FEL and weight box 10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller |
Congrats! That looks great compaired to my old tiller Ben got off me. If it turns freely I'd let it be.
See your yourself! http://www.onlycubcadets.net/forum/s...ead.php?t=8474 |
Nice find on your tiller.
Fleetline,
Nice to see someone else diving into the tiller restoration. Someone on here posted some very nice shots of a tiller they had just done and it got my juices flowing too. I see you tipped it up on end and then spun the unit with the pulley right? If it really spins free then you may be fine. My bottom bearings were shot. I did not know that until I took it apart. So I did not have a choice. I see your dust covers (on the bottom bearings) are in much better shape than mine. That could be a good indication of acceptable bearing condition? The gear box on a #1 or 1A tiller was about the toughest diss-assembly that I have done in a long time. But when going back together it really made a big difference. I did not find a lot of other folks that have taken these all apart. Which means that most that spin will keep spinning for a while longer As I have thought a lot about these for the past month I think the addition of a port on the top of the gear box that would allow you to add some lube would be a good addition to these. I did not do that (yet).Your 1A looks very similar in condition to the #1 I worked on. FYI all new bearings (6 items ) from Cub dealer will set you back about $300. I will be watching! Regards, Chris
Casbohm Maple and Honey www.mapleandhoney.com Cubs: 147R and the "train", 127 elec lift, 127, 125, 106, 102, 100, 86, 73, Brinly plow, Snow thrower, 2 Rototillers, several mower decks and several snow plows, #1 cart, Grandkids barrel cart. |
Hey Curtis that tiller looks familiar. Oh yea we moved it from the trailer. I would wish you luck but who needs luck when you have skill. And thanks again for letting EricR and I over to see your herd and thanks for the supper. Yes folks we had a little mini central PA get together on Sunday.
With my son, EricR Super 2084 with 54" mower, 451 blower. 2086 with 3 pt hitch, 54 inch deck, 551 blower, 54 in brinly blade. A 4 digit original w deck. A 70 with deck. 2 102s both with 42 in decks, one with creeper, 1 36 inch IH snow thrower CW36, 1 42 inch IH blade. 149 with mower. 2072 w 3 pt hitch, Johnny bucket, 60 in mower, 451 blower. Jacobson GT 10 with mower. DR Lawn vac tow behind,Home made lawn roller. Brinly cart, 2 off brand carts and 1 home made cart. |
I had no idea the bearings were so much. I just wanted to know it's in good working order and you can see it needs painted. It does turn nicely. I'm thinking $300 would have paid for one in better shape. I did think I would have to open it up but that would have been just to inspect and change the lube. One would think there'd be a fill and drain for it. If you drill into yours be mindful of the metal shavings getting inside. (Lots of grease on the bit.) I have another 1A with no extensions but the pulley isn't connected inside so no telling what's going on in there. I was using WD-40 but I went ahead and got some PB B'laster for it today because of this site. I last used it like 20 years ago and wasn't impressed. That could have just been because of whatever I was working on. I'll start a new thread when I get it fully disassembled and can really work on it. Curtis
If this takes two weeks of soaking like your steering did I'll be needing to do something else while I wait. I may not be able to get those tine shafts off in the end but that won't be to bad. At least until it needs gone over inside. I do have a sleeve on a bolt I can't get to very well. It has to come off to free the lower arms and it's really giving me grief. I'm all set to get an electrolysis tank going but I don't know if it can be done outside in the winter here. Wouldn't that freeze??? I don't want to try that inside. I suppose I should start in on it with a wire wheel. It's all apart save those last three parts.
