i know this has been covered a thousand times and i have read many of them. we just got a cub dealer here in town and i went to talk to them about the type of hytran fluid they carried and gave them the cub fluid number. they showed me the fluid which is made by harvest king. universal. and on the back it says recommended for replacement of international harvester hytran fluid B-6. what are your thoughts?
Does the hydrostat fluid circulate both through the hydro pump and the rear end gears on the cadet?
I pulled the plug out of mine yesterday afternoon at the top of the rear of the rear end gears and could not reach the fluid with my little finger. Obviously its going to need some. I was thinking my full size Cub used 90 or 140 weight in the gears. Dave |
i can get this stuff in pints gallons a 5 gallons. just need to know if its the good stuff.
![]() Quote:
Yes, it is the same fluid...the rearend is the reservoir for the hydro pump. A Farmall Cub probably uses 90W, but these don't. This information is in the service manual and owner's manual. cmatthew- The generic fluids don't seem to handle water the same way that Hytran does. When water is mixed with Hytran, it globs up and sticks to the inside of the transmission or goes to the filter and stays there where it can't hurt anything; generic fluid does not do this- it stays completely separate from the water. The generic fluid may meet the same specs, but it's not the same stuff. |
thanks mattg.
You can use whatever you want. It is your tractor. There is NO equivalent to HyTran. It is a patented formula. There are similar fluids but that is it.
Here is what is recommended.... HyTran
