I received the power steering valve by mail and would like to clean it out. Does anyone know what to use and how best to do it? When I turn the shaft it gurgles and spits but I'm not sure what to do next. Also, below is a diagram of the PS system and I would like for any of you who know which is the pressure side and the suction side of the system to help me be sure I have it right. I have #9 as the pressure and # 6/8/12 as the return. Is that the way you see it? It's hard to see it on the picture but #9 goes into the valve at the "In" port and #8 goes to the "Out" port and #7 goes from the "Aux" port up to the lift valve. The other issue I will have is that I have the other style lift valve and will need to convert the ends of 1862 lines to the old style fittings. Any experienced person want to chime in on this? The ram lines and ports are marked clearly and should be no problem. The picture sorta makes the lines look real long but in real life the bottom of the valve to the bottom of the lift valve is only about 10 inches.
That makes #7about 10 or 11 inches long. #6 will be about the same but will go to the "T" fitting.
1811 Hydro "Failing to prepare is preparing to fail".
Rudy, there is a detailed section in the 72-82 series service manual. I have not done one yet but I will soon. I hear that JD is cheaper on the parts. Make sure and take some pictures for us...you know how we are.
Yeah, I was surprised that the JD stuff was so much cheaper but when you go on their web site you see 350 viewing at the time you are on it. Our's is about 50 or less most of the time. I missed out on steering valve at $126 but got the next one for $125. The CC models are going for the high $100's to low to mid $200's. Just be sure and get the 5 port model. Evidently they made a four port model that won't work on our CC's. It looks like a straight bolt on except for fabricating the lines/hoses to fit the new configuration. Once I bought the JD GX335 which had PS I could not go back. To be able to turn the wheels in either direction while stopped was amazing. I did not want to keep the JD but wanted to keep and use my CC 1811 that I have come to know and love. We are both old and need work to keep us going! As soon as I get some parts I will break out the camera. I know what picture freaks we all are too. I'm still waiting for some help on the hydro fittings for the new lines.
I got the ram and a whole box of hard lines today from Rich at Patton's and started my testing assembly of all of the parts. The ram went on just like the book shows however when I turn the wheel to the left it hits the ram before it runs out of turning room. I did not have the drag link on so maybe that will help. The ram lines hooked up without any issues but that's where the fun ended. Rich sent me a long line that will fit from the tranny output port (pressure) to the #9 input port on the steering valve but the original 90 degree turn from the tranny is too far out on the new line and hits the drive shaft flex joint. Is there a way to cut the line and re-flare it with the end fitting still on the line? I can slide it down to where the line bends but I don't think there will be enough line to get the flare tool on. The line from the valve aux port to the hyd raise/lower valve is pretty simple and should not be a problem. The mother of all line problems is going to be the return lines that all come together and then back to the tranny. Chip, who sold me the front 1862 axle said that he used brake lines and flared them himself. I haven't been able to find anyone in my area that sells the end fittings. Do any of you know a source for the 3/8 fittings? In the pictures below you can see the line with the 90 degree bend next to the OEM line and where I have straightened the new one some. If I did get the new line cut and flared how would I put the 90 degree bend back in the line so close to the fitting?The next pic is the ram hitting the left front wheel. Then the box of lines that Rich sent to help me out and finally the steering column that I had to add about 10 inches to.
I got my 3/8 fittings at Napa
Jed Proud to be a FFA member Westmoreland,TN Chapter 1978 Cub cadet 1450 IH Hubcaps 1975 1650SGT Work In Progress 1974 cub cadet 129 with sleeve hitch/spring assist 1974 108 (Mint) #510358 brinly 12 in plow,disc,8 in plow ,2 42, 2 44A ,50A DECKS #40 boxblade,can`t keep up with the rest lol ![]() ![]() ![]()
That's the first place I tried but they said they don't carry that stuff any longer. Even their brake line selection was one little rack and they were all pre-made.
