Old 03-21-2012, 09:13 PM
krhoover krhoover is offline
Default 1450 mule drive
I had problems last year with the flat bar on this surging in and out, well it was more like hammering in and out. I put a new belt on it (from the dealer), greased and looked everthing over well and couldn't see any thing wrong. I was no fun mowing with the way it surged and the hammering noise. It has the slot in the front where the flat bar is beat up pretty bad. I would like some other opinions about this before puting it back on.
Some questions.
1. How much play should the two pulley's have.
2. The flat steel that the pulley's are bolted to are bent, but they look factory bent?
2. Should the steel rod move back and forth. It has cotter pins on the outside.
Any help is appriciated, thanks
Old 03-22-2012, 01:58 PM
Donovan M.'s Avatar
You should build new bars for the pulleys.
Donovan:
62' Original-fenders
Old 03-22-2012, 02:47 PM
Is your deck a 44 or 50A model? If so the pulleys have to be angled that way so the belt can match up the offset deck pulley. There really shouldn't be a reason for the tension bar to be hammering like you are describing. Are the mule drive pulleys in good shape? Smooth rolling? Is the 1/2" bar that holds the spring and pulley brackets worn or bent? I like to put a new bar in place of an old one anytime I get a new mule drive.
Old 03-22-2012, 03:41 PM
It's a 44"
Old 03-22-2012, 06:48 PM
Ok, I have a piece of 1/2" rod. Its good tool steel, not just cold rolled. Is the rod 1/2" straight all the way. Whats the trick to getting that spring back into place? It looks like the old one may have a bend to it and is worn where the spring rides on it.
Old 03-22-2012, 09:20 PM
Yes the rod is straight all the way thru. It's actually not too hard with the spring. You will notice there is one or maybe two cotter pins holding the pulleys in position. I would start with the one that uses the wrench to tighten it and just slowly progress from there. It's all pretty self explanatory when you get into it. I've done three of them in the last couple of years and not had any problems putting them back together.
