Need some ideas on how to compress clutch spring to put the roll pin in. I know they make a special tool for this, but i do not have it. Any ideas? Thanks
![]() Quote:
http://www.onlycubcadets.net/forum/s...ead.php?t=4640 |
I stick the 5/8" shaft in a vise and clamp slightly. the spring is resting against the vise.
Tap the shaft end with a soft face hammer. When the spring is compressed enough, tighten the vise, and install the pin. When you realize the hole is not properly oriented to allow you to get the pin in, slowly release the vise, realign and start over!! ![]() |
A couple weeks ago my son and I rebuilt a clutch on an original and had to replace the spirol pin that is at the end of the long spring. We used a vise while my son braced the engine end of the shaft in front of his hip and grabbed the vise and compressed the spring I tightened the vise and changed the pin then slowly let the vise loose and viola pin changed. It pays to have a rather strong person do this and pad the end of the shaft but it worked for us without having to find someone with a press.
With my son, EricR Super 2084 with 54" mower, 451 blower. 2086 with 3 pt hitch, 54 inch deck, 551 blower, 54 in brinly blade. A 4 digit original w deck. A 70 with deck. 2 102s both with 42 in decks, one with creeper, 1 36 inch IH snow thrower CW36, 1 42 inch IH blade. 149 with mower. 2072 w 3 pt hitch, Johnny bucket, 60 in mower, 451 blower. Jacobson GT 10 with mower. DR Lawn vac tow behind,Home made lawn roller. Brinly cart, 2 off brand carts and 1 home made cart. |
Matt
That looks like it would make it an easy job. Nice design work. ![]() |
Thanks, ended up using a press with an oxygen sensor socket, worked great.
