Old 04-12-2012, 10:04 PM
fordrat fordrat is offline
Default 1050 viberation
Last summer while mowing, the drive shaft broke in my 1050. It destroyed the clutch disc in the process. I replaced the shaft and disc with new parts and now when I let the clutch out I have a real bad vibration. Clutch in, no vibration. Any thoughts? I'm kind of lost on this one.
Ricky
1862 50"deck
1050 44"deck (serial #785548)
108 (serial #2050043U427916)
'61 Original (serial #47610)
Old 04-13-2012, 11:04 AM
tex599 tex599 is offline
Did you replace the throw out bearing as well? Did you check the shaft to make sure it is straight? Not much that would cause a vibration, other than a bent drive shaft, bad bearing or a misaligned drive disc. Just replaced the clutch in my 1050, let me know if you have any questions.
Old 04-13-2012, 02:26 PM
Like I said, I used new parts. I rolled the drive shaft, and it seemed straight. But, I didn't replace the throw out bearing. Probably try that. My question, could it be something in the transmission? I really like this tractor, but can't use it in the shape it is in. Thanks for the help.
1862 50"deck
Old 04-13-2012, 05:50 PM
Is the clutch visibly wobbling when you are experiencing the vibration?
Old 04-14-2012, 01:40 PM
Maybe. I can't really tell for sure as it has to be engaged for the vibration kicks in.
1862 50"deck
Old 04-14-2012, 02:11 PM
Maybe set the rear up on a couple of jack stands?
