How many folks make their walking rows 36" or more wide to allow dragging a cultivator behind their IHCC for weeding? If not, do you set up crop rows you can drive over? Photos please!
I used my hiller and made my rows wide enough for my BRS to go between using my home made cultivator.
![]() Tomato Section: ![]() I don't have pics of my regular garden section yet. But it is set up the same way. I can use either my cultivator or my disc set between the rows. About 48" between rows.
I use my cultivator every year:
I use 32" rows(oc) for the Cub Cadet w. CC 100 cultivators. This is my 1st year using the Cubs, used to use the MF TO35 w old Ferguson 2 row cultivators and had wide rows(42").
Just curious, Are the tires in above photo a bit under inflated?? I tend to overinflate a bit on ags and under on turfs.
CC 126; CC 122; CC1450; Brinley plow; Brinley cultivators, CC front blade; IH 48" peg tooth harrow. & 1320 Ford New Holland(EEK!!!) |
this will be my first year using a 2 row. the center knife comes off to cultivate
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
Thanks for the replies.
What do you do when the crops get too high to drive over? |
That's why I made mine wide enough to drive between.
I put mine about +-4ft so I can run my 1650 with a #2 tiller between the rows
Adam Current Workhorses: 1977 1650, Sleeve hitch, #2 tiller; 1985 782, QA 42A snowblower, 50'' deck, 42'' blade, Ags, IH Wheel weights; 197? 1250; 1976 1250, hydraulic lift, 44'' deck, 54'' blade (currently needing a engine) Current Projects: 1970 107, Sleeve hitch, 42'' deck, Tri Ribs, 8'' Brinley Plow Family owns over 30 tractors, 7 combines, 2 bulldozers, 2 mid size trucks, 1 semi, too many truck and scouts to count including parts, and 3 pulling tractors. All vintage IH. |
