Old 04-27-2012, 11:35 PM
mrcubcadet's Avatar
Default CC 1200 (1600) Project
Well, as some of you might have saw...I have been looking for a WF roller, to put a freshly rebuilt .020 over K341 in, out of my 1650.
I was planning on fixing the 1650 that it came out of...but got looking at some of the places where the motor mounts have put holes in the frame (wear over time) and decided to get a different frame, and to get away from the ISO mounts.
Joe (Jluster) and I have decided to do some trading, and tomorrow I am getting his 109 with a blown motor. My plan is to put the K341 in it.....with a 3 speed/clutch from a 124. Then I will call it a 168...
Will try to get some pictures tomorrow when Joe gets here.
-105___ Tiller
Old 04-27-2012, 11:48 PM
Sounds like a good plan.You will have to change the brake lever on the brake pedal rockshaft from a gear drive also.
Old 04-27-2012, 11:55 PM
jlampe94's Avatar
jlampe94 jlampe94 is offline
Heavier spring for the clutch might also not be a bad idea with the extra horsepower, sounds like a cool project!
Original,100,123,129,1200,1250,168 in progress (3) 42inch plows, QA-42A,#1 tiller, 10inch brinly plow, Case Ingersoll 224, 1948 Farmall H, 1950 McCormick W-6, 1952 McCormick W-4.
Old 04-28-2012, 12:03 AM
mrcubcadet's Avatar
Thanks! I suspect it will be mean with a 12" plow!
I have 3 bare wide frames that were gear drives. I can get the lever from one of them.
I wonder if the clutch out of a 1806 was much different than the 1x8's.
My first Cub Cadet was a "148" built from a 86, and I tried everything except a new spring to keep that clutch hooked up!!
The clutch would just slip in third gear. Very disappointing build.
I did ask a lot of that tractor though,,,
It may have been due to my fluid filled tires, lots of inertia to overcome.
My QL 1000 will do more than the 148 would do.
Interesting...maybe a 1806/582, or even a pulling spring.
Will defiantly have to look into putting a heavier spring in it. And thanks! Always have thought it would be cool to try it!
-105___ Tiller
Old 04-28-2012, 12:06 AM
mrcubcadet's Avatar
Maybe Dale (Merk) will chime in. He once told me about using a cultivator spring.
-105___ Tiller
Old 04-28-2012, 12:15 AM
mrcubcadet's Avatar
Here's the medium-duty spring Chris Westfall sells..... http://www.cubclassics.com/BLUE%20CLUTCH%20SPRING.JPG
-105___ Tiller
Old 04-27-2012, 11:54 PM
Old 05-07-2012, 07:31 PM
Looks great Conner!
Old 05-07-2012, 11:01 PM
mrcubcadet's Avatar
Thanks guys!
-105___ Tiller
