can this part be welded or does it have to be brazed as it was before which seems to have not been correctly done
It depends on the guy behind the shield!!
It is easy to braze, but, quicker for a skilled welder to weld with nickel rod. |
Any mild steel wire will do. Stick weld or with a mig, which ever one you have available. Easy fix.
luke |
![]() Quote:
You might be able to get some snot globs to hold it together but your best bet now is to have somebody else braze it again. |
I snapped the ear off where the bolt goes through the front roller. This seems like a cast steel piece (not cast iron) . I welded it with my mig. It did weld like cast steel, not smooth like regular steel, but it has held for a couple of years now.
thank you all for the info I will have it welded and see if it holds.
