I was going to do some work on my 1811 with my new-to-me mig welder and the unit quit. I just bought it and it is a MATCO unit that they no longer sell. I cannot make out what the wall electrical requirements are from this picture and was wondering if any of you read foreign wiring diagrams. Does this show two hots and a ground or two hots and a neutral? Thanks
BTW, the colored wires are the welder's plug. If I ask this question on any of the other departments no one will see it.
1811 Hydro "Failing to prepare is preparing to fail". ![]() |
It looks like it can be wired for 110 or 220 and shows the different wiring arrangements accordingly.
CCC 784 w/ Triple Hydraulics IH 982 Cub Cadet Commercial H1748 Walk-Behind 50C Deck 42" Hydraulic Angle Front Blade 41" IH Rear Blade QA42A Snowthrower |
If you just bought it I'd ask the people you bought it from. If it is defective I'd want my $$$ back. You could or should also check with an electrician. We don’t want to have to start calling you Sparky.
Looks like it is dual voltage. 115/230V-1PH.
The green/yellow wire is ground. Depending on the voltage you use, the other wires are L1 & N, or L1 & L2. If 115V, the Blue wire is Neutral
It's set up for 230 v and my outlet is a three slot two hots and a ground, not two hots and a neutral. I just wanted to be sure that my wall outlet was set up properly. One of the two 400 ma fuses blew and I am getting a replacement for it. It might be the fuse or it might be something else. I understood the diagram on the unit which shows two hots with the yellow/green as a ground but then they threw in all of the other stuff and it kind of confused me. Is there ever a set up where 230 v has two hots and a neutral?
Rudy, yes you could have 2 hots and a neutral but there will always be a machine ground. As Roland said you have 2 hots and a machine ground if your running it on 240 volts.
