Quick 44A type deck question.
Are these decks ground supported, i.e. the rear wheels ride on the ground similar to a Simplicity or Wheelhorse - or do these decks hang from the tractor? Thanks!!!!!! Bill |
Hang from the tractor. On level ground, IE: concrete or flooring set to mower deck to the correct mowing height you like then move the anti scalp wheels down till they are as close to the floor as possible without touching it. This should have you set up pretty good. The lift stop cam on the right side of the tractor can be adjusted to stop the deck at the exact height you want for mowing. I use a permanent marker to mark the spot once I get it right. This helps in setting it back correct if you have to take the deck off or put on other implements.
I agree with DX3!! the wheel height is somewhat dependent on the terrain also.
Those wheels are supposed to hit "occasionally". Regular contact will wear them out fast!! If you mow rough terrain, set them a little higher, they last longer. |
Does this apply to the haban decks too?
I have a modified 50C deck and I have it setup to let the wheels rest on the ground when mowing.
More info PLEASE!
