Old 05-21-2012, 07:39 AM
JSFRIED215 JSFRIED215 is offline
Default Cub 1641 boggs down
I have a cub 1641 with the briggs 16 horsepower with the 48" deck. When mowing after about 20 yards or with any speed above creeping the engine boggs down the shoot gets clogged i have to stop clap the deck. The tractor seems to run great on real short grass but other than that it doesn't, any suggestions,, i did just remove the deck clean it and spray down with wd-40 so the grass wouldn't stick. Help the slightest bit. Kinda acts like i am always mowing wet grass but i am not. Also cust grass only shoots out about 2 feet. Thanks for any help.
Old 05-21-2012, 10:44 AM
Lots of possibilities with this one. Is it a mower or engine problem? For the mower check
1 Blades sharp and the lift wings are not worn out.
2 Spindle bearings greased, in good condition and they turn freely
3 Belts in good condition not slipping
4 Idler pulleys good condition and they turn freely
5 Grass build up on the underside
6 Baffles in place.
7 PTO working properly
Engine
1 Tuned up
2 Clean air filter
3 Clean fuel
4 Clean fuel filter
5 Valves adjusted to spec
6 Carburetor clean and working properly
Old 05-21-2012, 10:52 AM
The tractor runs good, i use it to blow snow in winter time and it seems fine, has new blades on it, new mule belt, underside is clean but cloggs up quickly because blades slow down when bogging.
Old 05-21-2012, 10:58 AM
Is it the engine that is slowing or the blades?
Old 05-21-2012, 11:10 AM
Its both. Almost like an rpm drop. Runs great under no load though. WILL ACTUALLY STALL THE MOTOR IF I AM NOT CAREFUL
Old 05-21-2012, 11:15 AM
OK if that is the case you have something binding up or you have a problem with the engine not making enough power. Look at the list of things to check and see if that helps.
