Old 05-22-2012, 10:15 PM
bmbigdaddy bmbigdaddy is offline
Default hydro rear getting hot
I mowed the other day and sprayed my 1210 off and seen steam coming off the rear. The fluid was a little low. Would that be the problem or could something else cause this ? Thanks for the help.
Old 05-22-2012, 10:30 PM
The cooling fins on the hydro pump need to be clean, and the fan needs to have all of its blades intact.
Old 05-22-2012, 10:45 PM
the fan is clean and in great shape i have not had this mower long and cleaned it all very good when i got it i have only used it twice
Old 05-23-2012, 12:38 AM
Ozcub's Avatar
Ozcub Ozcub is offline
If new it will probably have 10w/40 oil in it that may not be good enough for a hot climate
20w/50 is recommended for a hot climate
Old 05-23-2012, 06:12 AM
A 1210 uses Hytran, not either of those.
Old 05-23-2012, 07:03 AM
They do build some heat, it is not a good idea to spray cold water on anything hot, as they cool down suddenly among other things, they tend to suck water into the innards.
I would think this temp is typical.
