Old 06-03-2012, 01:39 AM
rikers74's Avatar
rikers74 rikers74 is offline
Default 1811...Hydro help
Hello. I'm new here and had a few questions. I recently picked up an 1811 that needs a lot of work. It's in rough shape cosmetically but the engine and trans are still going hard. I plan on totaly rebuilding and could use some help.
My first item of concern...I'm trying to pick up an additional set of rear wheels and want to know if a set of JD 24x10.5x12 wheels will cause any concerns on the Cub. There's only an inch difference. I know they're not Cub wheels, but funds are tight and the price is right. They would be used to put AG tires on for the garden.
Second...the steering won't turn the same distance to the right as to the left. When I turn it to the right and kick the left wheel, it will almost finish the travel to the stop but not quite. I've cleaned all the built up dirt away but it's still not 100%. Is there a way to adjust the steering to fix this?
Third...can I adjust the Hydro trans? When the trans lever is in the neutral postition the tractor wants to reverse. I have to put the lever forward about half an inch to get it to sit still. When I apply the brake or use the Hydro lift, I can hear and feel the trans trying to move the tractor. This can't be good. Am I destined to have to replace the trans plate or springs?
These forums are a new thing to me. I appreciate any and all assistance relating to forum and the Cub.
Thanks,
Joel
__________________________
1987 Cub 1811 Hydro w/ 3pt and ball hitch
44" deck
IH 46" plow
Agri-Fab pull behind broadcast spreader
LoadHog trailer
Soon to own...Cat 0, single bottom plowplow
Old 06-03-2012, 07:20 AM
(1) It's your tractor. YES, they will fit. Hope you will paint them Cub Cadet white though..
(2) Turn your steering wheel all the way to the right. Take a piece of Masking Tape and place at the "12 o'clock" position on the steering wheel. Rotate the wheel in the opposite direction. Count the number of turns to get there (ie: 3 or 4). Now rotate the wheel back to the "mid point". Disconnect and adjust your steering linkage(s) so that the wheels are straight forward. Reconnect linkage(s) and you are good to go.
(3) Click on this link........and follow the link within. Go to page 2-57 and follow instructions for Hydro Neutral Adjustment........... Service Manual
Old 06-03-2012, 09:10 AM
rikers74's Avatar
Roland,
Absolutely Cub Cadet white! They will only be used for the dirty @*#% work and only until I can get some "real" wheels. I thought I might get some "dirty"looks from that one.
As for the other info...I will work on those concerns today and update.
Thanks.
Joel
Old 06-03-2012, 10:18 AM
Make sure the offset on those JD rims will work...I know that many other manufacturers use an offset that will not work on a CC with external brakes.
Old 06-03-2012, 10:21 AM
rikers74's Avatar
Thanks Matt. I just found another guy selling some actual CC wheels...gonna get them instead.
Old 06-07-2012, 01:07 AM
rikers74's Avatar
Ok. I adjusted the steering and the Hydro as best I could. The drag link is bottomed out on both sides and I still have about 1/2 inch of lost travel, but to the left this time. Should I try adjusting the tie rod now?
The Hydro is better...I noticed the damper spring plate wobbles back and forth a lot. So much so, that in one direction the tractor wants to move in Neutral and in the other, if I hold it there with my hand, it seems fine. The outer compression spring seems very loose and as if it is not giving any pressure on the pin spring guides. It appears that if the compression springs were tighter, the damper plate may not rock from side to side. Just a thought. Suggestions?
Yesterday I picked up a Sears moldboard plow in great condition. Looking forward to hooking it up and tearing up some dirt. Tomorrow (today) I'm headed North 3 hours to PA to pick up the CC wheels I found and my new-used hood is on the way.
Thanks again guys for all your wisdom.
Tags
1811, hydro
