I was using the tiller for the first time the other day and I rattled my 1650's muffler guts to pieces. There is a chunk flopping around and I think it blocks my exhaust every once in a while because I get some lack of power like it is missing. I see that the vendors have 2 different mufflers for sale. The one like I have that has rolled on end caps and a newer version that has welded end caps and supposed to be 35% quieter. Is one preferable than the other one? The PO fabricated a new front grill out of expanded metal and did a pretty good job. I have seen some Quitelines with the exhaust out the grill and some not. the newer replacement muffler has a longer exhaust tip that I would have to shorten or cut a hole in my grill. What is the advantage to the ehaust going through the grill. I'm guessing it is to reduce eating up the grill. I have a nice ring of soot where my exhaust is hitting it. I have also head references to a muffler crutch. I have seen pics on Kirks custom engines. Does anyone have prints to one so I can fab one up already and have it ready to install with minimum downtime.
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood. |
Grills ahey?
Hummmm.I custom fabbed a grill for my 1450 in a couple hours. Course I had to make it with a half inch flat steel outer boarder, and I used larger grid expanded metal. I started by making a cardboard pattern first. I'm waiting for the paint to dry so I can bolt it in place. I suppose you want a picture to. You'll have to wait till I get one took. ole 147 |
I wanted the heat out, so I just used a piece of shelving, bolt cutters were used to cut it.
![]() Vice-Grips bent the ends of the wires. Since TSC had paint on clearance, maybe it will get painted soon!!
