A little help, please. I can't find out how to take the lift handle apart on my 44a deck. It drops down to the next notch while I'm mowing. Seems like it might be the spring, but not sure how to get to it.
for any
OK,I found it! The top button is supposed to unscrew. I'll try that.
Well ive got two that the top button was frozen and no matter of pb blastor or time helped the button on top that was frozen and it broke and is partway still there so be careful how much twisting you do! Any suggestions to fix my probblem?
1782 smoker!!, 169 and parts 128 And a bunch of stuff that fits on the back of them LOL |
Mine came off pretty easy!!!! I couldn't believe it.
![]() If you have the rod out of the handle, I would try tapping on it with a hammer against a vice or something solid. If that doesn't work, try heating it up to expand it. Hopefully there is enough left there to get a hold of to unscrew it.
Unfortunately no it was already broken and nothing to grab on to, I'm figuring a drill and no fun to be honest! Then get some parts from the folks at the top of the page any other ideas?
I had the same problem on my 125. The way I finally got mine out was to cut the lower bend and weld it back on. If you do get the rod out it won't be straight and it's a pain to get it back in. Hope this helps.
