Old 08-13-2012, 03:59 PM
fleetlines's Avatar
fleetlines fleetlines is offline
Default Importance of Fan?
I was talking to an old guy that worked repairs in a Cub dealership. He said the fan on the drive shaft doesn't really do a whole lot. He said in 40 years working there he never encountered a problem due to the loss of the fan. What do you all think?
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights
72, Serial #231093, K161S Serial #C281773, 36" deck
149 & Original Yard art
1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch
1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted
123 FEL and weight box
10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller
Old 08-13-2012, 04:03 PM
Merk Merk is offline
I find another Cub Cadet dealer.
Project Uncle Dick
Cub Cadet 70
Old 08-13-2012, 04:31 PM
ajcombs's Avatar
ajcombs ajcombs is offline
I agree with merk mine needs replacing as its missing one blade but it puts a ton of air out the back of my 149 when running... It might not cause immediate trouble but cool things run and last longer.
Old 08-13-2012, 05:59 PM
I talked to a IH Cub Cadet mechanic of 40 years and he says that the drive shaft fan is important because the hydro pump gets HOT when you are running it. This is one of the reasons why it is unpainted. He also recommends cleaning it off with compressed air (the hydro pump) when stuff gets built up so it'll run cooler. I also agree with getting another dealer. There is a reason the factory put them there.
Old 08-13-2012, 06:21 PM
It's your tractor, run it with no fan and tell us how that works for you.
Old 08-13-2012, 06:33 PM
cub123's Avatar
cub123 cub123 is offline
The hydos get hot enough with a fan, especially when plowing. I can't imagine running one without it. I know you sure can feel a lot of air coming out of the back of a super.
Old 08-13-2012, 09:14 PM
fleetlines's Avatar
He wasn't anyone other than someone I met a long way from home that wanted to talk cubs. Strange how that happens with one on the trailer. I had always heard they were very important just as drglinski said and this was news to me. I also often refer to the fact that "there is a reason they did it that way", especially with IH. Just wanted a second, third, fourth and fifth opinion. Mine broke on the 1650 which is what brought the subject up. I've not done one - yet - but they look like a pain. I'll have to see. Thanks for the input.
Old 08-14-2012, 09:54 AM
dieseldan123's Avatar
Mine is missing from my 1650 also. And i had replaced one in a 1450 and yes they can be a pain. There are two ways to do it. You can unbolt the grille, engine and slide the engine forward to then take out the shaft, or you can split the tractor by unbolting the rear end and sliding it out of the frame to get the shaft out. Ive done it by way of the engine and talk about a headache getting everything lined back up again! But i think that's the nature of the beast for the hydros.
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
