I just bought this old girl and the owner said its charging but I can tell it aint. Just for the fact when you turn the lights on they are very very dim even when its running. He by passed the voltage regulator. I found the wires but is the one for the batter suppose to be hot at all time or only when its on? I need a little help with it. Its does have the 16hp kohler still
Brandon CC models: 86, 100 w/hanban sickle mower & 1872 1972 86 w/12" brinly plow & 65lb wheel weights & 42" grader blade 1965 100 w/hanban sickle mower 1989CCC 1872 w/50c mower |
well i tried it and i cant get anything out of the stator...all i know is tht the guy i got it from had it rigged to charge and it didnt charge. the more u turn on the more it pulled down the battery...but i tried hooking it up like it shows on the diagrahm and it only makes the wires get hot.
It sounds like you will need a new stator and then to repair the wiring so that is it able to be connected correctly.
Here is a list of links for your quiet line that may help you out with many of the issues that come up with them: Quiet Line Links: Download and print all the manuals; Carb Rebuilding: http://mgonitzke.net16.net/tools/carb_rebuild.pdf ISO mount and snubber: http://www.onlycubcadets.net/forum/showthread.php?t=7 Hydro Filters: http://www.onlycubcadets.net/forum/showthread.php?t=12 Ignition Circuit: http://www.onlycubcadets.net/forum/showthread.php?t=27 Ignition Coil: http://www.onlycubcadets.net/forum/showthread.php?t=11 Spark Plug Chart: Use Autolite: http://www.onlycubcadets.net/forum/s...ead.php?t=4638 Static Timing for new points: http://mgonitzke.net16.net/tools/static_timing.pdf Chassis Service Manual: http://www.onlycubcadets.net/forum/s...ead.php?t=4644 Kohler Service Manual: http://www.onlycubcadets.net/forum/s...ead.php?t=4646 1650 Operators Manual: http://www.onlycubcadets.net/forum/s...ead.php?t=4670 PTO adjustment: http://www.onlycubcadets.net/forum/showthread.php?t=30 Wiring Diagrams: http://www.onlycubcadets.net/forum/showthread.php?t=22 Cradle Mod: http://www.onlycubcadets.net/forum/s...ead.php?t=4630
for the uneducated here...what exactly is a stator and why is it needed? Do they fail often? Is there a similar part on an auto engine? On a Kohler 3xx, where is it and how big a job is it to replace it?
I'm not being a smart-a**...I really want to know! When I read the OP, I would have suspected the VR but I really don't know anything about a stator. Is it possible that jumpering around a bad VR would kill a stator or will a bad stator kill a VR? |
| Tags |
| 1650 |
