I have found another super cub . It has a 60" haban deck with it but no mule drive . Will the mule drive for my 50" cub cadet deck work for the haban deck ? Thanks Bruce S.
Yes. I had a haben and sold it but kept the extra mule drive for my 782. They are identical.
Red '84 Cub Cadet 782 50" Deck, 54" Power Angle Blade, QA42 Blower, #4 Cart, #2 Cart, 400 Rear Tiller, IH Rear Grader Blade, IH Rear Rake, IH CI Weights, Rear Suitcase Bracket, Sleeve Hitch, Front Hyd. |
It will as long as you have the lift arms for the Haban. There are a couple different versions of the 60” Haban and what I call the Cub/Haban 60”decks. Also the lift links are different lengths depending on what age tractor they are going on and they used two pulleys depending on the PTO size. The Yellow one is the later Cub/Haban the White one is the early style.
Thanks for the reply . I have the early deck , and i did end up with the mule drive for it but I didn't get a rear stabilizer bar. Every thing is smooth and quiet . I'm not sure it has a lot of hours on it just been out side most of it's life . Thanks Bruce S.
