I am considering buying a rear blade for my 2072... Is a 48" rear blade wide enough? Also, if you have a haban blade on the front, can you operate the two together or one at a time?
Thanks!
982 with 3 PH, rear pto, front & rear hydrs & ps, 1772 w/3 point, rear PTO, 86, 2 Haban 60" decks, Haban 54" snow/dirt blade, Brinly Cat 0 Disk, 5' blade & 2 Cat 0 Plows, SpeeCo Cat 0 plow, Sears cat 0 Cultivator, Cat 0 CC 442 Tiller, 60” rear mower, 450 blower |
they will run at the same time as far as i now. i would go to 60" my self because when you angle it you lose width so 48 you may be less then your tractor width when it is angled. I have a 60" myself
I suppose a Tractor Supply blade is too heavy...?
If you can find one the brinly BB 1010 5ft blade is a perfect fit
![]() There are a few company's that make a cat 1 that's about the same size that could be made to fit too.
Ben
That orange blade would look much better on my BX than your Red 982
